Network Surface Question
Hi! For school I am trying to create a network surface using the centroid of the geometry from the curves I created. I am unsure how to go have the after I moved the centroid into the y direction. I don’t know what I am supposed to plug into the network service input? ex) u & v input?
The end result I am trying to get from creating the network surface will be attached as well as screenshots of my files and a zip file containing them!
grasshopper example|690x152
Parametric wall.zip (180.0 KB)
Open to any and all suggestions!
Thank you!
This entire geometry was already solved for you here by @anon39580149
So why not just reply there that you cannot get it to work? For me I just open the file and it works fine. By making the thread again, any new person will miss all the previous work and have to start all over.
I don’t have the necessary plugin to work in that file.
I should have referenced the previous post, apologies.
@Michael_Pryor is the developer of the plugin used in the file.
Ask him if you have problem; and you can download the plugin, why you can’t use it?
U is curves in the U direction. V is curves in the V direction. NetworkSrf | Rhino 3-D modeling
