I can’t get the surfaces to adapt to my curves with network… Why? Can anyone help me? Thanks
As you can see in “C” the shape is a rounded rectangle and transforms it into an ellipse and in “A” the surface does not follow the guide.
You might want to reduce the tolerance…
If that doesn’t solve the problem, post your file with the relevant geometry.
i agree, that is most likely the problem. a tolerance of 5 is huge. to be fair if one does not know about tolerance, in this case it would be very much misleading. it could also mean amount of curves, meaning higher would be tighter.
Thanks a lot guys, it was that, reduce tolerance. I thought it was the other way around, greater valué, more resolution ![]()
