.NET upgrade
Rhinocommon is listed as depending on .NET4.5 on NuGET.
Is it possible to upgrade to a later version? Other packages I want to use require newer versions of .NET. Is it safe to just change the project target to 4.8?
Best,
Aske
Rhino 6 has a minimum requirement of 4.5
Rhino 7 has a minimum requirement of 4.8
Both versions will use whatever is the latest version of .NET installed on a users computer, these are just the minimums that the installer makes sure are there.
You can definitely target a newer version of .NET
Awesome! Thanks!
