.NET Core which version to use?
So Rhino .NET changed from .NET framework to .net core.
I am trying to migrate my old plugins. All visual studio projects has only .NET framework.
I would like to install .NET Core. Which version should I use?
Would the .NET Core 8.0 would be ok, or must I use 7.0?
It would be great if someone could share experience how to create a grasshopper plugin for .NET CORE 7.0 from scratch.
I installed somehow new template above, now during compilation I get this:
Rhino 8 currently uses .NET 7.0.111, so best to get .NET 7.0.
You can ignore the warning for the potential incompatibility.
I just installed 7.0
Still there are these reflection errors.
How to get rid of them?
I have no clue what they mean…
Change Build + IntelliSense to Build Only.
edit: Also, you probably need to make sure you don’t have automatic assembly info enabled.
edit2: In your csproj file:
    <GenerateAssemblyInfo>False</GenerateAssemblyInfo>
    <EnableDefaultItems>False</EnableDefaultItems>
in the first <PropertyGroup> tag.
Switched to Build Only.
Where the automatic assembly option could be enabled?
I added the info for assembly stuff in my previous message.
You can silence NU1701 warning by adding this in the first <PropertyGroup> tag:
<NoWarn>NU1701</NoWarn>
By adding this, build worked:
The other flag somehow did not allow to add any C# file, so I do not use it.
Another question:
By default visual studio builds net48 and net7.0 projects, should I skip net48 and build only 7.0?
If you target Rhino 8 and later only for the project probably easiest to target only .NET 7.
