Good Morning,
Is it possible to create a .net core plugin for Rhino 7?
If so is there a Visual studio template i can install to set things up? Alternatively how may I set this up manually?
Good Morning,
No. You can’t. You can use .NET Standard 2.0, though.
Are there any plans to support this? or are we waiting for .net 5?
I think adopting .NET Core may shake the current infrastructure of Rhino SDK, therefore leading to breaking changes for all kind of plugins. Don’t know how McNeel would tackle that.
RhinoCommon is compiled against .NET framework 4.5, but the Rhino executable usually runs a newer version of the framework.
We are not switching over to .NET core during V7 development and will re-evaluate when we get around to working on V8.
What library are you trying to reference?
Thanks,
– Dale
Thanks Dale, that makes sense and seems reasonable.
Thankfully I am trying to reference internally developed code.
I’ve switched to .net standard and .net 4.5 as appropriate.
Hello @dale
Has this question been reassessed ?
What interests me is the possibility of unloading DLLs which has no alternative in .NET Framework.
Rhino 8 for Mac is currently using .NET 6. We are investigating the use of .NET 6 in Rhino 8 for Windows, but it is still currently using .NET 4.8. Windows is a trickier situation because we still need to support execution in a .NET 4.8 runtime to support certain Rhino.Inside implementations.
Ok I see, thank you.
