Nested noecho osnap command for Keyboard Shortcut
for example I did This:
NoEcho '_Osnap _Mid _Enter _cancel
alone it works perfect as a simple Mid Osnap Switch, without appearing at the command bar. My knowledge lacks after that. why this command couldn’t be nested even " ’ " character exists? i.e. when in move command, if I use the shortcut the switch works, but it also cancels the move command. is it because of _cancel?
Can you guy suggest why this happens and do you have better idea? BTW this is just an experiment. not expecting big things though.
