Nested JSON string prettyprint correctly
this might be a rather odd question and acutally has nothing to do with Rhino.
But as I want to embed a nested JSON-string in a block description, I thought it might be okay to put that here.
I have the following object:
import json
class Rhinoceros(object):
    def __init__(self):
        Length = 0
        Height = 0
Then I create the object and I wanna store a custom JSON-string, that I migth wanna read lateron. This literally can be anything and I wanna be felxible here.
When I do the following:
test = Rhinoceros()
test.Length = 1000
test.Height = 100
text = """{
    "Name": "T.",
    "Age": 20,
    "Weight": 100.0,
    "Height": 20.0
test.Data = text
print (json.dumps(test.__dict__, indent=4))
This will result in this:
“Length”: 1000,
“Height”: 100,
“Data”: “{\n “Name”: “T.”,\n “Age”: 20,\n “Weight”: 100.0,\n “Height”: 20.0\n}”
Is there any way to make this readable like in the string above?
I might do a workaround here, no question. But maybe there’s an easier way?
Thanks,
T.
HI @tobias.stoltmann , why not use a dictionary?
text = {
    "Name": "T.",
    "Age": 20,
    "Weight": 100.0,
    "Height": 20.0
print(json.dumps(text,indent=1) )
@Darryl_Menezes , hi.
That’s what I acutally did and that’s where the string comes from.
When I “store” it in the other object it’s working fine.
The moment I wanna convert that object to a json-string it concatenates it that oddly.
Oh I see. You could parse the JSON string before assigning, something like this
test.Data = json.loads(text)
This question probably doesnt belong in this category though
Correct as always, @Darryl_Menezes .
And I agree with the wrong category.
