I noticed that STEP doesn’t import as nested blocks anymore. Not even having nested layer structure (as discussed / proposed with @brian ) Not even being an option. Any other unpleasant surprises?
UPDATE: BTW, this (not being a nested block structure) breaks one of my workflows, as I was using the nested block structure to create my layers structure in order to keep parent-child relationships coming from CATIA.
Okay, it’s V6.
What specific service release introduced this change in behavior?
What I need from you is a simple STEP file with nested blocks that I can use for testing to verify the problem.
Then I can report it and get it on the pile to be fixed.
Okay, so the step is imported properly here (at home) I updated Rhino yesterday here. I’ll check tomorrow at work which version I have there and I’ll get back to you.
