I noted this odd behavior when working with nested linked blocks:
- “Assembly 1” contains two linked block instances of the “Cube” file.
- “Assembly 2” contains one linked block instance of the “Assembly 1” file.
- I drag and drop the “Cube” file as a linked block into “Assembly 2”, but then I cannot edit the “Cube” block, moving or deleting it. If I save “Assembly 2” after inserting the new block, this will not show up the next time I open “Assembly 2”.
Blocks.7z (32.3 KB)
