Good afternoon.
Could I get some assistance with the GH code and the exercise below?
In the GH attached firstly, I am constantly getting an error that says " The name “a” does not exist in the current context - line 125". Could someone explain why I keep getting this error? It works once but then when I try to run it again the error appears.
How could I add more attractors and repulsors to the code? Would it be possible to add different colors as well to display the intensity of attraction for each grid point ?
Thanks in advance for any help.
A3.gh (7.3 KB)
Need to internalize Point param?
- Error (CS0136): A local variable named ‘a’ cannot be declared in this scope because it would give a different meaning to ‘a’, which is already used in a ‘parent or current’ scope to denote something else (line 84)
- Error (CS0103): The name ‘a’ does not exist in the current context (line 125)
You men adding a Boolean component?
Thanks
Will
Get the general case on that matter (and you don’t need a class for similar simple stuff … unless you want to do queries, monitor each object with some properties … blah, blah). On the other hand using DataTrees (custom collection valid only in GH) restricts the portability to other apps (if this is the case with you).
As a challenge replace Boxes with Spheres (or anything else) but have in mind that bing N of non rectilinear geo slows things down.
Box_RandomOrtho_WithAttractors_V1.gh (123.9 KB)
