Nest multyple surface with holes?
Hi guys, how to nest multiple surfaces with holes?
nest.gh (11.7 KB)
Give input to Geo - a planar Surface, not curves.
Internally I convert planar surface to Polylines and identify which ones are holes and which one is the boundary.
can you make example pls?
Did you check example files when you downloaded OpenNest?
yes, and “project” item doesnt work
It is not project. Please download and open example files.
I could have helped with your files, but you did not internalize data.
not in the gh,just in the rhino,use the command “meshpatch” ,1wireframe,2 all the hole
This is done inside OpenNest no need to extract any curves.
