Neon: Blurry decal upon rendering
#1
Great to see a forum instead of a newsgroup!
My first question:
I applied a decal to a surface and rendered it in Neon. The decal is a screen capture at 624x1000: very sharp and clear, text quite readable.
However, in the completed Neon render, the decal is quite blurry, as if an aliased representation of a lower resolution decal had been used. What am I doing wrong?
Link to image here:
Thanks in advance!
John
Sarasota
Help: It ain't cool with low-res flames :)
(Willem Derks) #2
Hi John,
2 shots in the dark (not my expertise):
Does setting a larger texture size in the render options makes a difference?
Or might disabling texture compression improve quality?
-Willem
(Andrew le Bihan) #3
Increasing the texture size will work.
#4
Thank you both very much!
Increasing the texture size did the trick.
