Hi, I am having an issue when attempting to put my model into shaded view. It is taking forever and whenever it does finish, it gives me the air message, “Render meshing failed or was canceled. Switching to wireframe display.” I don’t know what to do because I’ve never had this problem before. This file is not big at all compared to other files I have worked with in the past. I also already checked my drivers to see if they are updated and there is nothing to update. Any help would be appreciated. I am also running on Rhino8
Rhino 8 SR13 2024-11-12 (Rhino 8, 8.13.24317.13001, Git hash:master @ ca3666c3ebed2b9567e10930077bfa0884f65db9)
License type: Educational Lab License, build 2024-11-12
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: LAPTOP - Unplugged [43% battery remaining] ~60 minutes left
Primary display: Intel(R) Iris(R) Xe Graphics (Intel) Memory: 128MB, Driver date: 1-18-2024 (M-D-Y).
Primary OpenGL: NVIDIA GeForce RTX 3050 Ti Laptop GPU (NVidia) Memory: 4GB, Driver date: 6-25-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 556.12
> Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-25-2024
Driver Version: 32.0.15.5612
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.13.24317.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.13.24317.13001
This is what my SystemInfo gives me
First see if there are bad objects. _SelBadObjects.
If that doesn’t reveal anything, you can send the file for inspection.
Hi Gijs! Is there a way to find out if something is a bad object? I actually was able to get it working again by deleting an object I suspected was the bad object, but I was wondering if there was a systematic way to figure out what the bad object is so I am not guessing in the future. Thanks!
As mentioned:
Thank you!
solved ?
please mark solution - thanks.
