Need to disconnect/reconnect Revit "Add X" GH Components
Has anyone had my recurring issue that after making changes of some kind, sometimes, I get a persistent “Managed Exception was reported: Transaction was Rolled Back and Aborted” on a component like the Rhino.Inside.Revit “Add Grid” component, for example. When I disconnect the geometry input and reconnect it, the error goes away and I am good. In the image below, you can see a component with error, and without error after my workaround fix. I have been using this workaround for a few months and thought I would put it out there–Am I missing something?
Brian
Hi Brian, A canvas refresh doesn’t clear this?
How are you using your definition? are you using it over and over in the same project or is this being used on various projects?
You have a lot of wires going on, is that something that could be grafted into one component?
Hi Japhy
Not sure what a canvas refresh is, and web search doesn’t show this function.
I do plan to combine all this into one component–I just have to set up my list of source curves to match my list of names. Actually planning to use User Attributes to automate the naming.
But would this current messy approach affect the Managed Exception Error?
Can you isolate a small example that we can look at? Thanks
Thanks @Japhy
I will provide this when I have a second.
