When working with meshes I regularly need to add mesh faces that don’t fully connect to the existing vertices. Can you please add that function to the AddMeshFace command?
Currently I use a script I made, but it would be better with an integrated tool as it could also include mesh edge as starting point, and also other curves.
#Add_Mesh_Face
#By Holo 2016
obj=rs.GetObject("Select mesh to add face",32)
if obj:
vertices =rs.GetPoints(draw_lines=True, max_points=4)
faces=[]
if len(vertices)>2:
if len(vertices)==3:
faces.append([0,1,2])
if len(vertices)==4:
faces.append([0,1,2,3])
mesh=rs.AddMesh(vertices ,faces)
newMesh=rs.JoinMeshes([obj,mesh], True)
rs.SelectObject(newMesh)
rs.Command("_UnifyMeshNormals", False)
rs.UnselectObject(newMesh)
