Need multi import script support
I have a script to import multi files downloaded from the forum and modified it a bit accordingly. But the problem is that when importing files, the order of imports is by size. I want to change the import order by name, how do I change it.
I use google translate to ask questions so it might be a little difficult to understand importMultiFile.rvb (2.9 KB)
@Helvetosaur - it’s got your fingerprints on it… =)
Oooh, vintage! 2013…
Hmm, it would be a one-liner to sort the file names alphabetically in Python, but in vbscript… Let me look.
O, how I hate working in VB script…
I don’t know, here when I import a folder with the original script the files are already sorted by name alphabetically. So I don’t really know why yours behaves differently and how to check. Does the following work any better?
ImportMultifileTest.rvb (3.5 KB)
If not, I’m afraid I can’t help you much.
@Helvetosaur There was an error during useCapture
As I said, I’m afraid I can’t help you much here…
@Helvetosaur thank you very much. I will try it again. The VB script is a little annoying
