I need to find someone with
skills to evaluate the load bearing capacity of a pressed earth brick dome for my project
that will be realized in Canada.
the dome is 50 feet diameter, made of clay/cement/sand bricks with a precise mix, bricks have
been tested for their compression capacity
I want to put a roof on top of the dome that would sit on it contacting the dome at 8 points ( or more depending on your recommendation )
you might want to contact the block research group here in Zürich, ETH
https://www.block.arch.ethz.ch/brg/about
they do all this kind of compression only shells - and published also some software to calculate it. kind regards -tom
