The following is part of a Rhino 2.0 command script –
! split
zoomextentsall
When this block is pasted into Rhino 2.0 command line, split first executes zoomextentsall and afterwards requests the object that should be split. This is shown by the following command history –
Command: Paste
Command: split
Select objects to split: zoomextentsall
However, I want the split command to first completely execute without invoking zoomextentsall. Then aftersplit completes, zoomextentsall should execute. I seem to remember that there is a way to do this but now it eludes me.
Per your first suggestion, if I preselect the object and then paste the following –
split
zoomextentsall
Then zoomextentsall still executes as part of split. The command history shows –
Command: Paste
Command: split
Select cutting object. Press Enter to clear selection and start over: zoomextentsall
Per your second suggestion, if I paste the following –
! split
pause
zoomextentsall
Command: Paste
Command: split
pause
Select cutting object: zoomextentsall
Splitting… Press Esc to cancel
However, your second suggestion works if I use 2 pauses instead of one –
! split
pause
pause
zoomextentsall
Then the command history shows –
Command: Paste
Command: split
pause
Select objects to split: pause
Command: zoomextentsall
Apparently a pause is needed for each of the two commands that split executes (Select objects to split, Select cutting object).
