Need help with loft thickness
this ring i have made needs to be thicker because i dont want the inside of the shank to be too fragile. Any suggestions?
£2 ring.3dm (900.1 KB)
can you sketch the changes you want to achieve please ?
why don t you change the initial curves and do the same workflow again ?
there might be better workflows to get similar questions - check this forum for some other jewellery topics
Modify your input curves and remodel.
and maybe check the suggestions I gave you in the other topic:
… and by the way - it is not recommended to use special characters in filenames - especially if you send them to clients / machines / over several serves and different disk formats.
I would avoid characters / naming like “£2 ring”
They might cause problems
and for sure they will only in time sensitive context - and unexpected in the night before you finish the project…
