Hello, I’m new to Rhino and I’ve run into a problem filleting edges. I can seem to click and fillet every edge but one section on the left outside edge on my object. I’ve read that fillet edge is only for joined edges which I assume my object has, and if this one section doesn’t have joined edges how do I fix that?
Here you go Derekg. The problem is your surface and linework. I think you had self intersecting lines that created a bad surface. I redid the linework for you and lofted the curves and used the patch command to patch the sides. I used the fillet surface command to fillet the edges and it worked. I’ve attached the file as well. Hope this helps.
