Hi, I have been working on a simple project and need the end result to be laser-cut for which I need a flat diagram of all the contours on a panel. I have the script but its not flat . Maybe I am missing something.
poly_clock.gh (17.1 KB)
Hi -
The Project Along component puts all sections on the CPlane in your graph. Perhaps you are getting confused by the other components that also show a preview? You probably want to join the section curves (or, before that, the breps) before translating those, though.
The OpenNest
plug-in that you can install with the Rhino PackageManger
might make things easier for you.
I’m not sure what you want to do but I would use Brep Join before Contour?
P.S. Of course, you could contour in the XZ plane as well:
Perfect. Just what I was trying. Also I tried opennest to make it fit nicely.
Also, while we are at it I want to have to external surface as a square and be able to loft through. i tried making a rectangle orienting it to loft but it says all curves are open and hence cannot loft. Is there a way to have a square on the outer boundary, the polygon on the internal one and loft them.
