Need Help with an Organic Roof Structure for a Museum
Hi everyone!
I’m currently working on a museum project in Rhino 8, and I’m trying to develop a parametric structural system for a complex organic SubD roof.
I’ve attached an image of my current model. The roof has multiple undulations, raised areas, depressions, and funnel-like openings. I’m trying to create a structural grid that follows the geometry naturally, almost like a network of interconnected branches.
What I’m trying to achieve:
I want the structural members to follow the roof’s curvature while also extending down toward the ground at certain points, creating branching structural supports.
Ideally, these supports would grow upward from the ground, branch outward, and gradually merge into the roof’s structural grid. I want the entire system to feel continuous, rather than having separate columns supporting a roof.
I also want the structure to respond to the openings and depressions in the roof, emphasizing their depth and creating a more three-dimensional, organic appearance.
What I’ve tried so far:
I’ve manually drawn grid lines and projected them onto the surface, as shown in the attached image.
I’ve also experimented with topography-based approaches, but because the roof has multiple peaks, valleys, openings, and changes in curvature, the results haven’t worked the way I intended.
The main problem is that these methods don’t give me enough control over the direction, distribution, and continuity of the structural members, especially where the roof transitions into the ground supports.
What I’m hoping to achieve in Grasshopper:
  • Reference my existing SubD geometry directly, or convert it into a suitable geometry for Grasshopper.
  • Automatically generate a controllable structural grid that follows the roof’s complex curvature.
  • Control the grid density, spacing, and direction parametrically.
  • Have structural members flow around the openings and into the recessed areas rather than simply crossing over them.
  • Generate branching supports that originate at selected ground-level points and connect continuously to the roof network.
  • Ideally, have the branching supports and roof grid form one integrated structural system.
  • Eventually turn the generated curves into structural members with adjustable thicknesses or profiles.
I’m not necessarily looking for a conventional rectangular grid. I’d prefer something more organic, possibly based on flow lines, branching networks, or another suitable computational approach.
The goal is to develop a realistic architectural structural concept for a parametric museum roof, rather than just creating a decorative pattern on the surface.
My main question:
What would be the best Grasshopper workflow for generating this type of integrated branching structural system from an existing SubD roof?
Would approaches involving mesh topology, vector fields, Kangaroo, or other Grasshopper plugins be suitable?
I’m also wondering whether I should continue working directly with the SubD geometry or convert it to a mesh or NURBS surface before generating the structure.
Any suggestions, example definitions, tutorials, or recommended components would be greatly appreciated!
Thank you!
Dear @Sabah_Ousi
welcome to this forum.
did you look around a bit into other topics ?
do you know the great learning resources ?
your question is quite complex - so you my also want to look at this topic:
seems like a nice test scenario for AI
pop above post into RhinoAI, Raven, Rhino-Ant or others…
kind regards - Tom
Hi, Tom
thank you for ur reply, to clarify,
I’ve been working with my prof on this, and we are both coming up short. Each solution has too many limitations or dosent ig do what we want, so I’m asking for new commands to try or suggestions for Kangaroo files that achieve what we need parametrically.
Im studying and use Revit mostly and few years ago learnt rhino but grasshopper is new to me ive spent 4 weeks trying things and ive not reached one solution im remotely happy with so ive turned here for tequneces that i simply don’t know or new commands i can ask my prof to teach me how to do and I can experiment with.
Hey @Sabah_Ousi, I am not sure if it’d be the best way, especially if you’re looking for an ‘on-object’ growth/branching of sorts—but an easy thing to try is to rely on the 4-sided faces of the SubD—they can be perfectly usable for you to map structural modules (made out of line work) from a base 2D 4-sided surface, aiming to ensure they all repeat and connect throughout the 3D shape, before targeting the perimeter edge from which the modules will extend to the ground. You could play with layered ‘modules’ on the 2D surface, procuring various mappings onto the SubD, forming playful/experimental lattices—if you properly/cleanly intersect in the 2D you can eventually multi-pipe them on the 3D.
Alternatively, maybe the ShapeMap options in grasshopper can help?
