Need help with a rhi file created from python running other than runpythonscrip
Hi everyone. I created a RHI file from the .py file with rhinoscripcompiler, but when I ran a command from rhino’s command, an error occurred when I had to press esc to complete the command. Compared with the runpythonscrip and the newly created command, the command must press esc to complete the command.MultiUnroll.py (7.4 KB) MultiUnroll.rhi (11.1 KB)
If you are not aware, here is another method to create an rhi from python scripts:
If that method works then you know the compiler is having a problem. I’m not sure what the compiler does differently.
