Need Help with 3d Alignment
Hello
I’ve been using Rhino to design Stained Glass art, it’s very useful as the 2d drawings can represent the glass panels very well
Came across a complication now that I am making 3d pieces, I don’t know how to align the pieces in 3d plane.
I figured out a trick that has been “good enough” but it’s very time consuming and doesn’t work for more complex structures.
In the photos I raise the pentagons so they join at the corresponding angle, I end up drawing a reference line where I want them to join and then align them with 3d rotation as close to the line while using 2 Viewports.
They never fit perfect (by millimeters, which add up)
I kindly ask for help regarding 3d alignment of faces, I have heard of constraints (which I don’t know how to use) but maybe there is a more simple solution?
Thank you for your time, stay creative!
I tried finding that intersection and snapping to it…
and then after that measuring where a rotated polygon falls…
if you ignore my file tolerances’ deviation the answer is 63.435 rotation needed
Steps below:
Finding_Don-Decahedro.3dm (221.6 KB)
I think this approach should be pretty scalable to most prismatic forms.
G
Hi, thanks so much for the quick response.
Where did you learn to use those side menus?
I found them and I see there is a wide variety, now I want to learn to use them all hehe.
I’ll research videos, PDF & Forums.
Have a wonderful day/night
I’ve learned most of it here. There’s a lot more that’s what’s on the menus. The off-menu commands lists is extensive too, with over 1000 long I think.
Have fun!
Hi @joshua_mora
If you do a lot of these, it might be worth looking into Grasshopper/Kangaroo for this.
magnet snap assemble.gh (18.7 KB)
HTH, Jakob
don t want to be the lazy party pooper…
but there is a nice free plug-in to create polyhedra:
math
see dihedral angle (angle between two planes / planar faces / along edge)
here
Screenshot 2023-02-02 at 13.10.42
calculation
you can use
_rotate3d
and enter the angle as commandline-calculation
acos(-1/5*sqrt(5))*180/Pi
construction
my approach would be to use arcs to construct intersection points to get the angle.
to draw the first initial (green) arc you can
either draw circle around curve ( which would require the blue construciton lines)
or use a c-plane and project Osnap (faster)
_mirror (cyan)
_intersect
_rotate3d
Yeah, much cleaner!
Alternatively, for a Dodecahedron you could simplify and enter below as angle:
atan(2)*180/pi
i’m curious if constraints can be used in the WIP instead ?
_
c.
This seems exactly like what I was looking for.
I say seems because going trough setting up everything I learned many things are not compatible with Rhino 5, including Kangaroo2
I can’t install Rhino 6 on my current pc because it is 32bit but I will try to fix my broken 64bit one.
I’ll comment how it goes If I make it work and post my results with the script.
Thank you so much, and for the video too!
To all others that answered too, much appreciated.
Happy creations!
This sure seems interesting.
I don’t have much knowledge in math but I’ll research a bit to understand more fully, it gives insight on how to use the tools available in many different ways.
I will test this if my other pc doesn’t work, will check it out ven if it does, great practice :wink:
Thanks!
