Need help using Grasshopper to create dynamic grid of points
They don’t all go the same distance in the Pufferfish version, the strength is based on distance to the attractor. The effect is because as a spread you go to the outer points, as a pinch you go all to one point (the attractor). I could add some fall-off options in a future update.
