pabellon cintas transversal.gh (28.6 KB)
i apreciate so much your help
@Juan_Sarquez
Hi, It was exactly clear what should the end result look like, but…
First off, you need to graft you input curves in order to get individual lofts, instead of a single loft.
And the first vertical row of curve components is pointless. Also I used merge component, in order to explicitly define the order of input curves.
Is this correct?
I see that you are using Shift list for the last two curves, for the twist.
Without the Shift (or shift=0), it looks like this:
hi bro, its like this but the result its so weird, excuse me for my english
These are the curves you loft. The results are accordingly “weird”.
Adjust the part of definition that positions these two rows, and I think you’ll achieve the desired results.
EDIT:
Or even omit one of them.
thank you so much my friend.
