Hi peeps,
I am having issues with surfacing this transition with only single span surface only.
Please do not recommend me subd, network surface, or any solution that introduce multi span solution.
Any solution to this?
Thanks alot in advance!
Hi peeps,
Hi Nicholas - a patch layout like this may get you there -
making that actually look good may be a challenge though.
Hi Pascal,
Thanks for the solution! It is possible if you can provide me the working file as I intend to analyze the CV flow through the different surfaces you have created.
If you have already deleted, then it is totally fine. Thank you.
-Nicholas
