Need help fixing polyline measurement scenario
Hi everybody. I have a polyline script but when it works it creates a lot of annotation styles. How to edit a script to measure curves and lines and not create more annotation stylesDimClosedPolylines.py (1.7 KB)
rs.AddDimStyle() will add a new style every time. Try looking for your style before creating a new one. Use the FindName function of the document DimStyle table:
def CreateDimStyle(textHeight):
    dimStyle_name = "MyDim"
    # look for a dimension style of same name
    dimStyle = sc.doc.DimStyles.FindName(dimStyle_name)
    # if no style with same name then make one
    if not dimStyle:
        dimStyle = rs.AddDimStyle(dimStyle_name)
        rs.DimStyleTextHeight(dimStyle,textHeight)
        rs.DimStyleArrowSize(dimStyle,textHeight)
    # return the found or new dim style
    return dimStyle
Multiple runs of the change above results in only one new dimension style, “MyDim”, to be added to the document.
I tried to replace the final code, and an error occurred at the second run of the scriptDimClosedPolylinestest.py (2.2 KB) Capture
Ah, the rs. functions work with strings of the dim style’s name, not the dim style itself, so something like:
    dimStyleObject = sc.doc.DimStyles.FindName(dimStyle_name)
    if dimStyleObject:
        # get the name of the StyleObject
        dimStyle = dimStyleObject.Name
    else:
    # return the name of the found or new dim style
    return dimStyle
or slightly more direct:
    if dimStyleObject:
        return dimStyle_name
    # no style was found with dimStyle_name so make one
    return dimStyle
thank you. It works very well.
