i make a eto python script. I want compile it into file exe then install in another computer run with command but i don’t know how can do thats
Hi @xiix.xoox,
you can do that and compile a python script containing Eto related code using the RhinoScript compiler. The result is not an *.exe file but a *.rhp PlugIn file or, alternatively a *.rhi PlugIn installer.
Note: it is required to reference the RhinoCommon.dll
for Rhino6 if you’re using Eto related code in your script. You can choose the dll after opening the compiler, press P to go to the PlugIn setting, then press S to choose the SDK section. When it prompts for a file, select this file:
C:\Program Files\Rhino 6\System\RhinoCommon.dll
Here is an example PlugIn compiled using this method. It displays an Eto dialog. The command it registers is SampleSmile
: SampleSmile.rhp (8.5 KB)
_
c.
Thank you!
