Need Assistance with Removing the Inner Circle Walls
Hiii, so I’m trying to create a geometry based on these two tangent circles but I don’t need the entire circle. I only need a portion of the circle (an arc basically) ending with the two points that create that web in the middle. I don’t know if I should replace the circle with the arc, but it doesn’t flow seamlessly with the arc command (I’ve already tried)… I still want the geometry to expand and compress in size because I need to subdivide it later on. What suggestions would you recommend? Thank you
Note: the yellow highlighted portion is what I want to remove!
does this help?
arcs.gh (17.1 KB)
Yes, this helped tremendously! Thank you so much!!
