Hi
I work with interior project in Rhino and Vray
Currently, I model Wall, Floor, Door, Window, Ceiling in same file (call it Main file)
I model each plant, furniture in separate files. I insert these stuffs in to main file. Using Insert/ Embed and Link
Currently Main file is almost 500mb and I have to wait 2minute for saving. Need advice workflow to reduce size of main file. I also need update material for Insert file in Main file( I don’t want to come back each file to edit material because many furniture use same material)
Hi Travis - right, so if you ‘embed and link’ the geometry is added to the base file and that file will grow. If you want to keep that parent file small, link and do not embed the blocks.
