Hi
How could divide circle as below in Grasshopper
I intent to use red area to extrude.
Thank
Travis
Hi
Thank
Travis
Use Genepool or sliders or list of numbers
It’s just for the angles
Hi @anon39580149
How did you calculate these numbers?
I expect that white parts will be equal and the red parts will be multiple.
Thank
Travis
I choose them manually , you must already have the list of angles
Thank your feedback. It’s still not what I looking for.
You should have said that on the first post
You can use the angles here instead of gene pool and continue with Seghier solution…
Thank Ricardo
It’s good as expectation.
The white parts in your image are not equal size or angle.
