I Need a additional button in toolbar which will apply gray color with RGB 135,135,135 to a selected object.
Can someone please help me into this?
Thank you in advance.
You can create a button with the following Python code in it:
! _-RunPythonScript (
objs = rs.GetObjects(preselect=True)
if objs:
color = (135,135,135)
if color:
for obj in objs: rs.ObjectColor( obj, color )
Hello Martin,
Thank you for your quick response.
Yes it’s working in addition to what line I need to add to get object un selected so that I can quickly able to see that colour get’s changed.
Is there any way to add properties into this like name and which color?
Thanks a lot.
Name and unselect added.
You can also look at the example here:
rhinoscriptsyntax (rhino3d.com)
I took this and changed the color input to your grey color. The example let’s you choose a color
if objs:
if color:
rs.ObjectName(obj, 'name')
rs.UnselectObjects(obj)
