// Define planes for cutting
Plane Cutpl1;
Plane Cutpl2;
// Initialize a list to hold all cutting curves
List<Curve> CutCurvesList = new List<Curve>();
// Get cutting curves from the first plane and add them to the list
Curve[] curvesFromCutpl1 = Brep.CreateContourCurves(BrepInitial[0], Cutpl1);
CutCurvesList.AddRange(curvesFromCutpl1);
// Get cutting curves from the second plane and add them to the list
Curve[] curvesFromCutpl2 = Brep.CreateContourCurves(BrepInitial[0], Cutpl2);
CutCurvesList.AddRange(curvesFromCutpl2);
// If you have additional planes or curves to add, repeat the above step
// Example: Adding additional cutting curves from another plane
Plane AdditionalCutpl; // Define this plane as needed
Curve[] additionalCurves = Brep.CreateContourCurves(BrepInitial[0], AdditionalCutpl);
CutCurvesList.AddRange(additionalCurves);
// Convert the list back to an array for the Split method
Curve[] CutCurves = CutCurvesList.ToArray();
// Split the initial Brep using all the accumulated cutting curves
BrepCut = BrepInitial[0].Split(CutCurves, 0.1);
I think that you can find a better approach, but this will work just fine
Hope this sparks some ideas,
