We work with named views as the orientation are different than the standard views.
When we -import something, rhino will go true all the views and set them back to standard views.
The same will happen when i -insert with a button.(macro below) But will not happen when i -insert manual.
“-Insert
C:\Temp-rhino\Autorhinoexport.dwg
g
Enter
pause
enter
Company views:
Perspective / Aft view / SB View / Top
Standard views:
Perspective / Top / Front / Left
This problem does not happen in Rhino 5.
Can somebody help me to fix this problem?
Hi Nick - I guess this is with dwg and dxf files only, correct? I think that is the one plug-in that monkeys with the views.
For now, I suggest a workaround:
Make a template file if you do not have one with your views - presumably you do.
Add a macro to your process: _-ReadViewportsFromFile "Full path to template inside double-quotes"
Hi Pascal,
Thanx for the replay,
Yes this is happening with DWG files.
The work around will work for now. (if it works)
Maybe because it is almost weekend. I get a unknow command.
