Opening the Named Views panel hangs Rhino 8 indefinitely: one CPU core stays at 100%, memory is flat, there’s no disk activity, and the window shows Not Responding. I waited more than 20 minutes and had to kill the process. It happens again every time I reopen the file, so I can’t reach the panel to switch it to list view.
File: about 950 MB, many named views, PBR materials with 2048 px texture maps (colour, normal, roughness) using per-object mapping, including custom-mesh mappings, and many block instances.
Requests:
- Make thumbnail generation interruptible (Esc) or lazy, so it doesn’t block the UI.
- Allow switching the panel to list view without opening it (an option or command), and remember that choice.
- Skip or limit expensive display modes, such as Raytraced, when drawing thumbnails.
- Allow select named views to be imported from another file as opposed to all or none.
