Hoping for an explanation of what’s happening here, how to prevent it, and how to undo it it happens:
Hello- yeah, I see something is kooky with layouts - 4View
and then returning to the layout seems to sort it out if 4View
does not matter for the model views.
https://mcneel.myjetbrains.com/youtrack/issue/RH-49050
This must be new with a current release. It’s worked relatively recently. Activating/maximizing one of the viewports views seems to sort it out also. I’m not sure that the detail view is actually being reset though.
Hi @djhg,
I am unable to repeat what you are reporting here. Do you have a model that you can share that exhibits this behavior? Also, can you run SystemInfo
and post the results here?
Thanks,
– Dale
This project gets used only for the occasional print at this time, but if it happens again I’ll upload it. Do you want a copy of an iteration of the (very large) project from around the date of the first post? I doubt that there’s one that displays the behaviour without who-knows-how-much fiddling around (more than I currently can spend time on).
