Charles
1
When I save the first Named Position, Position 01
is the suggested name.
For the next one it is also Position 01
Means I have to manually edit the name.
Not very comfy.
I wish the suggested name would auto increment as i.e. in the Layers.
Even Rhino 5 did it:
Charles
2
@Gijs
Could you have a look?
Gijs
(Gijs de Zwart)
3
thanks Charles,
RH-79417 Auto increment named position name
Gijs
(Gijs de Zwart)
4
hi Charles,
apparently this was a change based on customer request. The way it works:
if the name is selected, it will use that name
if the name is not selected, it will auto increment.
does that work for you?
Aha!
This secret is revealed now.
Thanks.
