Named Hatch Pattern
Would it be possible to have named hatch patterns that incorporate rotation and scale specific to the file?
Hello- so basically a ‘save as’ button on the hatch interface, would that do what you need?
Yeah, for instance, I’ll select a hatch in my file - say a scaled down brick pattern and save it as “small_brick”. Then later, in another detail, I can apply that same pattern at scale and rotation without searching out the previous one and click under Saved Hatches, or whatever you choose to call it - maybe a similar feature to Named Views - and voila… small_brick is back.
Hi Brennan - added as https://mcneel.myjetbrains.com/youtrack/issue/RH-48342
In the meantime, at least some of the time, you can use the Match button in Hatch properties - assign any hatch, select it when done (SelLast) and in Properties, use the Match button to give it the same hatch as an existing one.
Thanks, that’s exactly been my solution and it works pretty good for now.
