I want to make a macro button to switch between these rotation modes. But I don’t know the name of the commands.
Hi @simon9, you can access this setting with a macro to set it to view or world, but there is no option for toggle. To enable view this can be used:
! _-Options _View _Rotate _AroundWorldAxes=No _EnterEnd
to enable world this:
! _-Options _View _Rotate _AroundWorldAxes=Yes _EnterEnd
To make a single toggle, a python script could be used which probably can be extended so it makes the views z-axis vertical after you’ve reverted the setting from view to world:
import Rhino
def ToggleViewAxisRotationMode():
mode = Rhino.ApplicationSettings.ViewSettings.RotateToView
Rhino.ApplicationSettings.ViewSettings.RotateToView = not mode
if __name__ == "__main__":
_
c.
Hi Clement,
Thanks for the help. I’ll just bind these macro’s to ctrl+alt+home and crtl+alt+end for now. I’m unfamiliar with python script and how to use it in Rhino.
Btw is there a list with commands somewhere on the internet?
Greetings,
Simon.
This will toggle between:
! _-Options _View _Rotate _AroundWorldAxes _EnterEnd
