Name and add viewport + named viewport
Hi everyone,
I would like to automate the creation of new viewports + named viewports. My usual process is:
  • create floating viewport
  • dock floating viewport
  • create a cplane with 3Pt
  • plan view to cplan
    - name viewport
    - save as named viewport
Up to the “name viewport” I got it covered with a command macro and alias. But I cant figure out, how to make the last two points happen.
Would be great, if someone could help me out.
Best,
Frank
Hi @Frank_Dahl,
To change the name of a view, script the ViewportProperties command.
_-ViewportProperties _Title Frank _Enter
To create a named view, script the NamedView command.
_-NamedView _Save Frank _Enter
– Dale
Wow, this is amazing. Thanks so much Dale!
First I thought you made a mistake, because you used an underscore and hyphen. But when I tried it without the hyphen and it did not work.
Could you point me to where I find documentation about this.
https://docs.mcneel.com/rhino/6/help/en-us/index.htm#information/rhino_scripting.htm%3FTocPath%3DScripting%2520and%2520programming|_____1
