Naked edge despite repair and also one floating in space
V5
I had this item, (the one below the problem item) then chamfered edge 0.0375 the hook item on one side, trimmed and joined surfaces, and of course then its got a naked edge.
I remove the surface and use sweep2 to fill it, and still its there, also there is a magenta naked edge line floating in space.
How can I have a naked edge not even on the object ?
I am unable to see how I can solve this.
Naked Edge despite after sweep2.3dm (1.5 MB)
I am also unable to Mergeface for the triangle shaped surfaces at A and B.
why ?
Cheers
Steve
Hi Steve - if you loft across these pairs of edges, you should be fine
