You guys are probably aware of this Exception occurring when you open the Properties panel when debugging using Visual Studio but I did not see a reference to it on the forum.
"An exception of type ‘System.ArgumentException’ occurred in Eto.dll but was not handled in user code
Additional information: Resource ‘Rhino.UI.Resources.Focal_blur_tab.ico’ not found in assembly 'RDK_EtoUI, Version=7.3.21039.11201, Culture=neutral, PublicKeyToken=552281e97c755530’
If there is a handler for this exception, the program may be safely continued."
If you continue, everything comes up. Please let me know if you have a solution or if I have something setup incorrectly in my localized environment.
I am using Visual Studio 15.
The ETO.dll I am referencing has an Update date of 2/8/2021.
It is in my C:\Program Files\Rhino 7\System directory so I think this is part of the update package.
I remove the Properties Panel before shut down then open it when Rhino has re-opened.
Again this does not effect Rhino opening without going through Visual Studio but I wanted to make sure you were aware.
Best;
Steve
