My system doesn't show points in shaded mode
my system doesn’t show points in shaded mode although in the settings they are turned on, when I got to wireframe all shows as whished.
Version 8 SR16
(8.16.25042.13001, 2025-02-11)
Hi Schnabel,
Please run the SystemInfo command and post the results. A small example file may be helpful as well. Thanks
Hi Japhy,
Rhino 8 SR16 2025-2-11 (Rhino 8, 8.16.25042.13001, Git hash:master @ d0f731de6fe2c5fdcad78ad80faf154307815f18)
License type: Commercial, build 2025-02-11
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 128GB)
.NET 7.0.20
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4090 (NVidia) Memory: 24GB, Driver date: 2-25-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 572.60
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-25-2025
Driver Version: 32.0.15.7260
Z-Buffer depth: 24 bits
Total Video Memory: 24564 MB
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.0.3.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.16.25042.13001
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
it happens with all files there is no specific situation when it orrurs.
this help?
Hi Kyle, unfortunately not, I click in “restore defaults” create a cube, in the views I set the status on “shaded” is see the cube, click on F10 and it disapears. With F11 it shows again, in Wireframe mode F10 works as expected.
F10 will not turn on control points for a cube (in any display mode). A cube is a polysurface, you cannot turn on normal control points for those. You can use SolidPtOn to turn on solid points.
F10 should turn on control points for curves and single unjoined surfaces in any display mode.
This is of course if you have not changed what’s normally under F10 to something other than default.
sorry for trying somthing wrong, i take a curve make the same procedure and the same result
Hi Schnabel -
What happens when you go to Rhino Options -> View -> Display Modes, select the Shaded item in the list, and use the Delete button to delete it. Then restart Rhino.
hi Wim, seems it worked :slight_smile: thanks
