My script doesn't work any more
Tower Script.gh (22.3 KB)
I had an old script using RIR from a year ago and it doesn’t work any more, how to make it works again!
for me it is working, I just added some new curves as input for the tower (although I have no idea of the dimensions that you were planning to use or the shape).
The only problem is that in some components, like Add Floor for example, you needed an input and the value for that was empty (although in some cases no value is needed, like in the case of Add Floor where a default value is assigned). Also set the Toggle to True, if you need to use it, otherwise the component will also work without connecting it.
In the case of the Add Wall component you need an input so just use something like this (and yes, next time you use the script you will need to choose a Wall Type).
Is this what you were looking for?
Tower Script_Edit.gh (43.7 KB)
If my file crashes, it is because the initial curves were too large :sweat_smile:
Thanks for the dedicated answer, IT WORKS like a charm
I forgot internalise curves :sweat_smile:
No worries, it also happens to me all the time :sweat_smile:
