screwdriver.3dm (1.3 MB)
Hello - please post the file or send to Tech@mcneel.com, and please include a link back to this topic in your comments.
I see it…
It’s my first topic sorry
and I edited the post with file
Hello - the file is in meters… probably a mistake, but in addition the tolerance is .01 units - that is a bit loose when you are filleting at .03 units - generally try to model at a tolerance 10X or more smaller than the smallest feature in the design. .001 would be better here.
see - https://wiki.mcneel.com/rhino/faqtolerances
That said, the problem likely arises here:
None of the edge curves are tangent there - some are close, others not. In addition, the curves (and the surfaces you make from them, have stacked control points -
that is the real problem here - If you clean that up and makethe curves all cleanly tangent, a new revolve should work better. (Change the tolerance before you start modeling)
