Mutiple objects on surface
Hello
I’m trying to distribute multiple objects on a surface. The SnapToSurf command arranges them so they point in the direction of the normal. I want to keep the original orientation on the cplane. Is there a way to do this?
Hi Andrew - I assume you meant OrientOnSrf. If you do not want the orientation to change, just use Move or Copy, with the OnSrf or PersistentOnSrf snaps set for the target points.
Hi Pascal
Thanks for the response. I’m using Rhino 4 so I don’t think have the option
OnSrf or PersistenOnSrf. Since I’m only using Rhino in my free time I don’t
get around all the commands, which makes me all the more grateful for your
help.
Any other options?
Regards
Andrew
Hi Andrew- these snaps are available in V4. When you need one, you can type it in and or grab it from Tools menu > Object snap, among other ways.
