Multiple Points (.txt) export order
In which order multiple points in cartesian coordinate system are exported?
I tried to export Points placed on different planes with default CPlane set.
Example with 4 Points:
planar to Top YX
30 20 0
30 -10 0
-10 20 0
-10 -10 0
planar to Front ZX
30 0 20
30 0 -10
-10 0 20
-10 0 -10
planar to Right ZY
0 30 20
0 30 -10
0 -10 20
0 -10 -10
Example with 8 Points (4 Points added in positive Z)
planar to Top YX
-10 -10 40
-10 20 40
30 -10 40
30 20 40
-10 -10 0
-10 20 0
30 -10 0
30 20 0
They are probably exported based on the order they were added to the file (nearest the top of the object list first… or maybe last).
Hello Helvetosaur.
Thank you for reply.
Looks like “diagonally” for 4 points “curve rectangle corner to corner” construction from bigger to smaller list values and for 8 points “unknown order”. I tried to place 8 points manually and by ExtractPt from “solid box diagonal” the results not the same.
Kind Regards.
