Multiple parametric parts in Rhino doc at once?
Is it possible or is there a plugin that would allow me to make a number of parametric parts through GH that would be similar to Visual Arq? I like the principle of Visual Arq but the parts are not really what I need. So I figured I could try to make my own. Or maybe there is a way to do this in Visual Arq?
Gh Player is nice but you can only run the alg once and after that you either would have to make a new part or redraw it. Thanks!
A little more detail or an example of what you are looking for would be sure useful to clarify your needs.
what problem are you trying to solve?
Hi Ryan -
As far as I understand, yes, you can do this in VisualARQ.
Apart from that, the changes in Grasshopper in Rhino 8 are getting you closer to being able to do that with native components. Baking is still missing but is being worked on.
