Hi Heath -
I’ll send you a few previous versions.
For that issue, please see the following post and provide feedback in that thread:
Note the AuditUndo
and TestCurrentUndo
commands.
Hi Heath -
Note the AuditUndo
and TestCurrentUndo
commands.
Thanks! Got the links. If I uninstall V8, will I lose my settings, or will everything come back just the way I had it? I’m super busy right now and saving settings and setting up Rhino all over again is outside my time limits at the moment. thanks
Hi Heath -
Uninstalling doesn’t mess with the settings.
As always, though, you should have a backup of important files. In this case, that would a copy of the following folder:
%appdata%\McNeel\Rhinoceros\8.0
Mitch created a script for a one-click backup:
Has anyone had a chance to looked at the [related] issue of the floating tools/panels not keeping their position on Mac with SideCar [iPad]?
Since it’s [i’d imagine] uses different connection tech then a regular monitor… it might not be the same fix as with the OP ?
thanks a lot
Ah, my third monitor is also using a different connection than the other two (and is a different resolution)
And the same issue is in the last V9 WIP I installed (9.0.24352.12305, 2024-12-17). Not sure if it was there before, didn’t try floating a toolbar on another window in V9 before.
My installation updated to Version 8 SR18 this morning and the multi monitor floating panel issue appears to have been fixed. Thank you!!!
OMG IT IS INDEED FIXED!!! Oh, this will be so much better. Thanks Team McNeel!
